I am the electrician on a job where the framer has (5) 2x6's together for a door jam.  The problem is that there is no room for a switch box (i.e. the window is 9 inches from the door).  Would you install a low volt contactor without box and run low gauge wire to relay below floor into basement, or install wireless?  Or would you hack it up with a router and knock plates?
