journeyman0217
- Tennessee
- Electrician
hey guys,
ran into an issue today that has me stumped. I just got done installing a 10 circuit 30amp manual transfer switch for a customer. the 120/240 30amp outlet on the gen. is gfi protected. at the end of my install I went to test operation in generator mode. I went down and turned all of the transfer switches in the "off" position, when I went to plug the power inlet cord in it immediately tripped the breaker and the gfci on the gen. being that the transfer switches were in the off position I assumed the was an issue with the cord or wiring from the power inlet to the transfer switch. everything looked good visually. to narrow down the possible problem I disconnect the feeder wire from the generator to the transfer switch. fired up the generator, plugged in the cord to the power inlet. this time the breaker held. I went down and made sure I had correct voltage between conductors. everything was good. with the gen off i connected the ground and neutral back up, both hots are disconnected at this put, fired the gen back up and go to plug the gen cord back in and it popped the breaker and gfi on gen again. i was wondering why the gfi was popping too, i threw my amp meter on the neutral to see if i had any stray current coming back on the neutral to the gen and read 0. next thing i threw the main breaker off to the house, fired the gen up again, and when i hooked the cord up it popped the gfi and breaker again! with the main breaker off i checked amperage on my two hots and read zero, threw it on the neutral and read .08 amps? figured that was the problem, some stray current coming back on the neutral to gen but when i stick amp meter on the neutral from the gen feeder wire it reads 0. also with the main breaker back on i read 2.9 amps on L1 and 1.9 amps on L2, neutral should have 1 amp but it reads 2.5 amps! went and check out service taps for possible loose neutral connection. visually looks good but i have to go back with a ladder. this one has me stumped because if the was somehow stray current on the neutral wouldn't this trip all the gfci in the house? i at a lose on this one......any ideas on what this issue could be? also customer is going to borrow another gen to eliminate the gen as being the issue.
