WAS....
And for what's worth I am quite familiar Isolated Power Systems.
Key words, "if done correctly".
Correctly? When some type of Line Isolation Monitor (LIM) is used that alerts the user there is a ground fault. At the very least an audible warning alarm. Also worth noting Isolated Power Systems should always be under the direct supervision of qualified personnel.
In this case the Isolated Power System does not have an LIM to warn the user. The ground faulted conductor, no longer an ungrounded conductor, just made it a Grounded power system. Does the user know that?
Beats me why you are continuing to beat this dead horse. A GFCI should never be installed on an Isolated power System, PERIOD!
Please look and find any UL Listed portable generator, that is wired as an Isolated Power System, that has factory installed GFCI protection. Please.
The only reason I am still posting on this thread is so some guy out there that bought a portable generator and Manual Transfer Switch from a box store is looking for the reason his generator keeps tripping the GFCI on the generator. How did he find this site? Just by using a search engine, like google, on his home computer and asking a question.
Hey them guys on the Mike Holt's electrical forum site are licensed electricians.
Just curious, what do you think the OP will end up doing to solve his problem? Will he lift the neutral on the portable generator? Is that what you are advising him to do? Or will he rip out the MTS he bought and installed, (eat the cost of his lost labor, and the cost of the MTS), and try to find one with a switched neutral?
I'll leave you with this again.
https://www.schneider-electric.us/en/faqs/FA177591/
In this thread I would be willing to bet the portable generator is Listed by an NRTL, probably UL, among others. The portable generator was designed and manufactured as a Grounded Power System. Its' intended use is for use as Grounded Power System.
Please keep in mind, only guessing on my part, the only time the portable generator will be used for the purposes of this thread, is in the event of a Utility Power Outage. Just guessing on my part, when not in use the portable generator will be stored somewhere else. Also remember this is a cord and plug connected portable generator.
