buffalonymann
- NC
Measure it with a 'scope. Then tell me I don't understand.
Connect the scope properly and then your readings will harmonize with electrical theory.
Yes. It will show that, on a 120-0-120, the two 120V legs are 180° apart.Connect the scope properly and then your readings will harmonize with electrical theory.
Umm..............P=VIcosφ for single phase. You need a √3 in there if you have three phase.
Current isn't work
Motors and rotating fields are deeply relevant to this discussion because they show how a 180 degree phase difference is qualitatively different from other values of phase difference.
With a three terminal source giving a phase difference of 120 degrees, using suitable transformers but no delay elements, I can construct any other phase difference I wish. I can take two legs (plus neutral) from a three phase system and use transformers to construct the third leg. I can convert from 2 phase to 3 phase. I can generate 'hexaphase'. Etc.
The same can be said for a three terminal source with _any_ phase difference _except_ 180 degrees. Without delay elements I can't convert a three terminal single phase system to a three phase system.
So while I agree that inversion causes a phase difference, that phase difference is in a very important way different from the phase difference seen in a true '2 phase' system.
-Jon
Yes, they are aligned but still different. Different but still existent.Motors and rotating fields are deeply relevant to this discussion because they show how a 180 degree phase difference is qualitatively different from other values of phase difference.
-Jon
if I have 3 phasesFor the "180 degrees apart" camp, say I have a device that measures voltage versus time between points A and B. And say I have two of them, and I hook up the second one with the leads reversed, so now I can compare the two graphs. What would you call the relationship between those two graphs?
Cheers, Wayne
What I don't understand is why they don't apply theory and derive conclusions from that perspective.
Nope.Would you just try to think of what current actually is; its clearly the work that's being performed. I assume you are now backing off of your assertion that currents cancel?
-Jon
I'd like that we were.These threads keep getting closed because we simply start calling each other names. I'd like to suggest we can remain polite and focus on the issues.-Jon
Define 'phase'.
To repeat what's been said...
Only if you use N as common reference, which is a choice.
