mivey
Larry,
Here is another way to think of the larger and smaller waveforms considering a 120/208 system.
If the "direction" of the larger waveform dictates the direction for the smaller waveforms and that in turn directs the positive direction in the coils then what do you get? You get one voltage at 180d and one at 120d that sum to get a larger voltage at 150d.
In other words, the larger voltage dictating "coil direction" would show two 60d displaced voltages. These voltages do exist but we normally define them the other way.
FWIW, we can actually make use of the voltage that does exist in the other direction because it is a physical reality, not just some math construct. We actually make use of the voltages in the winding halves in opposite directions in transformer banking and it works just like the math shows.
