Fladude38
- United States
I agree, it'd be nice to hear from the inspectors.
The thing about these requirements, including as AFCI, is whether the requirement actually limits receptacle location by stating a 'room' by its title [or inclusion using a catch-all item like 'and similar areas'].
Where the requirement doesn't mention a room by title limit the location to the room, it should state elsewhere or within the requirement how the measurement should be taken. I think it's realistic to measure via the shortest possible route a cord can be routed between end points. To think one should measure as x-rays travel... that would just be utterly unrealistic. To think the requirement excludes adjacent room locations is just reading more into the requirement than is actually there.
I'd personally like to see a revision of this in the 2017 or directly from the code panel with their determination, hearing what inspectors have to say is useless at best, like any of us, whatever they say is subjective. As the one guy already alluded to, cost and other factors don't come into consideration when throwing their weight around as someone with "Authority".
I think its intention is clearly described in the handbook " This change in
Code language ensures that tubs and showers in dwelling units
will have the same requirements for GFCI protection of receptacles,
regardless of what THE ROOM is called."
Its clearly stating that it is in regard to the "Room" the fixture is being housed.
Also, with the new rules, if that was the intention than it would also apply to ANY receptacle located within 6' from a bathroom, Outdoors, Kitchens, Laundry rooms, sinks (Not currently required in other divided rooms) and the like. Basically, 70% of the entire house would be required to be GFCI protected.
The intention (Lets say) in a bathroom is to protect the bathroom, if it was to protect the people from any capabilities from using other receptacles from being used in the bathroom than it would be required to be 6' from said room. Its not, its the room. Just as the handbook clarifies the intention, to ensure GFCI protection in the room to which the fixture is installed.
