FionaZuppa
- AZ
- Part Time Electrician (semi retired, old) - EE retired.
AHJ yes... but that's not the same as an individual representative of the AHJ, as in a single inspector.
i not following you. the inspector is a representative of the AHJ. if within the AHJ there is general consensus that a indi-bc ckt used for util equip should be just a single outlet, then i am certain you will lose in court regardless of the 13 other wiring scenarios that may still be "ok" by nec verbiage. if the intent is not clear via nec verbiage then it is up to the AHJ to clarify, even if you dont like their clarification.
if one inspector has a view that is way different than the consensus of the AHJ, then most likely an appeal to AHJ will rectify the issue.
