Smart Solar
- San Diego
- Engineer
I received this response from Bell/Hubbell:
Unfortunately, the weatherproof boxes are not tested at UL for internal drilling and mounting, and therefore, it is not included as an acceptable installation method in our installation instructions. Because of this, I am unable to provide any documentation stating it is acceptable, and have to defer back to the AHJ, and the local inspector for determination. Although it is a common installation method, that has been acceptable by most for many years, occasionally you will run across an inspector that will question the method.
The way to appease this inspector is to use the recommended installation method that uses the included mounting lugs. The 8 ways to mount, is marketing speak regarding the location, and the position of the mounting lugs, and their direction.
Let me know if you have additional questions.
