Redwood Infrared
- Arcata, CA, USA
Ultrasound indicated only audible frequencies
So, what are those frequencies ? all 60 Hz harmonics or ? Any current waveforms - elg harmonics?
What is the PWM operating frequency of the inverters?
Conduit span between clamps?
For instance, if the objectionable noise is at say 180 or 540 Hz, one could infer in phse harmonics on the core wires leading to the magnetic forces already mentioned. A 540 Hz whine sure could drive folks out of an office.
I should concede I merely inferred the hum is audible only because I could not pick up anything highly directional in the ultrasound frequencies. I assume if I could have heard an ultrasound squeal it would have revealed a point source of the problem but there just wasn't anything there at all. I also tried using a simple sound meter with a frequency analyzer in a phone app but even in the office environment the background ambient noise levels made it impossible to distinguish anything on a day with only 75% solar output. We might try that again if we get a good full sun day any time soon, and if so I'll try to gain access to the conduit above the ceiling so I'm closer to the source of sound and removed from other artifacts.
The inverters are Fronius 12.0-3 with frequency range of 45-65 Hz.
We do have voltage and current waveforms as well as voltage and current THD all monitored at the inverter combiner box, the AC Solar Disconnect, and the building's MSP over a period of about 3 days. Nothing was flagged as particularly unusual by the utility or the electrician. I and V waveforms looked normal to me, other than the 8A on the ground but that's been explained here.
I'm not terribly familiar with interpreting THD waveforms but will ask for permission to post them here if that would be helpful.
I'm not sure of the span between conduit clamps but it's on my list of things to check on our next site visit.
I would have guessed it was a higher pitch than 540 hz but I just listened to that on a function generator and yeah, that's probably a pretty fair guess.
