I think you best reread 250.24(A)(5) and rethink your position. 250.24(B) further supports my position.No, no, no. That is just saying that you can't use the metal enclosure as a neutral, you have to use the buss that the neutral lands on.
(B) Main Bonding Jumper. For a grounded system, an unspliced
main bonding jumper shall be used to connect the
equipment grounding conductor(s) and the service-disconnect
enclosure to the grounded conductor within the enclosure for
each service disconnect in accordance with 250.28.
There exists a possibility I am in error regarding my reply (post #19) to Rob's (infinity) statement (post #17) IF the tie bar can be called the main bonding jumper. I based my comment on the appearance of both right and left buses being isolated from the panel and assume the panel is bonded by a screw furnished by the manufacturer. I am viewing that screw as the MBJ.
