LarryFine
- Henrico County, VA
- Electrical Contractor
To do that, you'd have to be talking about at the ends, where the conductor is stripped for termination.drbond24 said:What I'm saying is that with water inside the insulation, there is a path for the current that shouldn't be there. It doesn't have to go through the insulation anymore, it can go around.
How do you connect a lead to insulation???When you connect the leads of the meggar to the conductor and the insulation, the water is a short between them.
All you're talking about here is making the 'contact' between the copper and the insulation more intimate. Who cares? Insulation is supposed to be insulative.You aren't testing the insulation at all, you're measuring the insulation resistance of the water which is going to be waaaaaaaaaaaay lower than the insulation. There is water in the copper and there is water on the inside wall of the insulation and it is the same water. You can connect your leads to the copper and the insulation but all you're getting is the water.
Isn't it?
