almost anyone can figure out how to press reset if they can see it.
Had many service calls for outside recept's not working and the HO could not figure it out.
Push Reset, $67.50 Have a nice Day
Seems like they're still in the making, but there's a P+S TR nightlight GFCI that maybe you could talk them into. The light would be a huge added security feature. No stubbed tootsies![]()
All I could find is part # PT1595NT, which is not TR, and is in the PlugTail series.
Well, of course.... "P&S Unveils New Tamper-Resistant Nightlight-GFCI Combination Devices".
I guess that's why it's not in their catalog.
They claim they want the 'fault' limited as much as possible to the receptacles only.
I have had this same request, and it was because of the misunderstanding that they thought the GFCI provided over current protection, after I clued them in that it does not, they changed their mind.:grin:
.......As far as lasting as long as kept dry i see no reason age would affect them. Is added safety with breakers but far less user friendly.
I am missing the point entirly here.:-?
His customers thought GFIs provided over-current protection, like fuses or circuit breakers. He explained they don't, so they didn't have them installed then.
He said GFCI's in the bedrooms? Around here all bedrooms have to be on arc fault breakers. I guess he could retrofit after final inspec......
you do that by installing an AFCI breaker in the panel and a GFCI receptacle at first outlet and line load it.
Does that work? Last I heard, the two weren't compatible.
