A customer wants a permanent generator installed for his 32 x 40 shop. The shop is so far from the road and around water so it would cost him thousands just to get utility power to the shop. This shop will only be used for general purposes and storage. Maybe a circular saw run every now and then. I am planning on 1 circuit for lights and 4 circuits for general purpose receptacles. And I will have this run by an LP generator.
My question is do I need to have a minimum of 60amp service for this pole building? The code says in 225.39D that "all other structures" need a minimum of 60 amp main breaker. If so, then I will need a 60amp producing generator right? Around 15kw or so depending on the manufacturer I imagine.
Or...
Can I install any size generator the customer wants because the 225.39D code only applies to utility power?
Thanks for your help.
Maven
Or...
Maven
