Carultch
- Massachusetts
Since European grids use between 220V and 240V to neutral, as the standard, it would make sense that the same circuit that powers the heating element, would power the controls and motors.Looks like this one puts 0A on the neutral,
at least based on the European version of the same model.
For a US version, it's very common that the oven would need to be adapted to both 208V and 240V, to work with both kinds of services available to residences (apartments for 208V and single/duplex homes for 240V). Heating power is only 3/4 the full capacity when running at 208V, unless there's a user configuration that modifies the heating element connections. Making a power supply for the controls and user interface that works on either voltage is easy, since switch-mode power supplies with flexible input voltages are very common today. Powering the motors is the hard part to make voltage-agnostic. You could use DC motors that are powered from the switch mode power supply, and that would allow it to be voltage-agnostic to work with anything from 208V to 240V.
