ptonsparky
Tom
- EC - retired
We have a VFD we installed last year that is suffering from over Voltage trips as of today. Lineside reactor is installed and is matched to the drive by the MFG. The drive feeds either of two auger motors via IEC style contactors. They are electrically and mechanically interlocked and must be closed two seconds prior to the drive operation. Drive stops four? seconds prior to the contactors opening. Coast to stop, which is almost immediate.
The times we have had overvoltage in the past it was PFC switching by the POCO, solved by line reactors, or ramp to stop with too short of ramp time. We have not been there yet but the operators are suggesting a relationship to a frequently cycling fractional hp motor. Could the starter coil on it be causing the grief a couple hundred feet away? This may be the first day they have both been run.
