I installed a new residential outdoor 200amp panel box on a new construction house. It is in the county with no inspection. I ended up having 42 circuits on the house. The panel box only has 40 breaker spaces. I installed a 125amp subpanel routing 6/3 romex for the main lug to the subpanel, and I also routed my 2ea additional circuits through the same offset out the side of the main panel box into the subpanel. I had to extend the branch circuit wires using wire nuts and more romex to make them long enough to reach the subpanel.
Anything wrong with that method? I read at one time not to route wires from one panel box to another, but from my memory it was refering to service wires being routed from the meterbase thru one panel box to another panel box, not running wires from a main panel to a subpanel.
