- Massachusetts
Re: Parallel feeders single phase
The feris metal is cut out and non-ferris metal is put in it's place.
What if someone drives a screw into a meter socket?
My point here is any installation can be what if'ed into a dangerous situation.
To each their own, my stake in this thread is only that some folks are insinuating the code must be twisted or ignored to provide isolated phase installations and that is simply not true.
No more than running multi-wire branch circuits is twisting the code.
That is your opinion, and that is fine. To some of us it as 'general' as wiring 20 amp branch circuits.Originally posted by milwaukeesteve:
This style of wiring that you are arguing is not general wiring, as you mentioned. It has specifics steps to take within the code rule itself, that is not 'general'.
I am fully aware of that, take a look at the picture I posted of the single conductor MI cable installation into a steel cabinet.Originally posted by milwaukeesteve:
Iwire,
You neglected to read all the reply. It is not just the locknut. It is any ferrous material that forms a circle around the conductor. That includes the cabinet,
What if?Originally posted by milwaukeesteve:
and like I mentioned, what if the dog's chain got tied around the pipe. As soon as it forms a circle, you have an electromagnet.
Again it is all just opinion, it is code compliant without 'twisting' or pulling apart the code. It is a design decision plain and simple. Any code compliant way can be the 'proper way'.Originally posted by milwaukeesteve:
Why would you guys even be arguing this? Like Shelco said, do it the proper way. Leave this type of installation for where you absolutely need it. (this is not one of those times)
