Most likely on the AC input side if it is a plain rectifierso, how is this thing switched on and off ???
it is by way of a "isolation" relay controlled by the MCUMost likely on the AC input side if it is a plain rectifier
CorrectMost likely on the AC input side if it is a plain rectifier
The original question was about paralleling rectifiers.it is by way of a "isolation" relay controlled by the MCU
the crude schematic is a components/module layout gram, hard to tell what is logical and what is physical. is the ATS switch itself a quad coil 3PDT latching relay, a pair of push pull coils ??
AC in, DC out from a plain rectifier.DC source 0.9 x ac V rms
switch
a resistor sized for a drop 1.4 V at SS current
an L sized based on 22 Ohm and 120 Hz
all in series closed loop
agreed, just get new single bridge, done.The original question was about paralleling rectifiers.
At the risk of repetition, the simple solution is to put in bigger rectifier modules.
To that extent, I offered part numbers for units that would probably be more than adequate for the application.
Best ask the OP that question.agreed, just get new single bridge, done.
but i am still curious about the switch, is it a 3PDT latch quad coil ?
No closed loop.
Closed loop systems require feedback that modifies the input to the system.Better be a closed loop or no i flow
Load is L inductive
load i = Vdc/R (1 - e^(-t/RcL)) upon switch closing
R = R1 1.4 drop + Rc dc coil
Error actuated and power amplifying is one good description of a closed loop system.
A plain rectifier is not an example of that.
Closed loop is gerenally taken to mean just that.we are not talking about a control system feedback control
like for voltage regulation or temperature regulation
Correct
this is a ge/zenith transfer switch
basically a few variations
1 rectifier supplying both the N and E coils
1 rectifier each
what do you mean by 1 rectifier each?
the dotted boxes are the control relays that feed "isolated" line V to the bridges, control relays are 24vac and are controlled by the MX100 (MCU).
to me this center section looks like 4 bridges and a quad coil latching 3PDT, or just a 3PDT with some sort of mechanical gang of the solenoids.
A series circuit would better describe your interpretation.
A crude approximation of the ckt?
switch
Fine. That's your take.a closed loop when discussing a ckt means one in which current can flow
Finegood.it's also Kirchoff's
The directed sum of the electrical potential differences (voltage) around any closed network is zero, or:
More simply, the sum of the emfs in any closed loop is equivalent to the sum of the potential drops in that loop, or:
The algebraic sum of the products of the resistances of the conductors and the currents in them in a closed loop is equal to the total emf available in that loop.
