Seriously, that is where you want to go with this.... Of course, it is a violation if it was left like that.. and of course, if it was fixed then it wouldn't be a violation. :? Not sure why you even made that statement. And if the job was done then it is a violation because there is no cover on it-- so what.. that is not what the op was asking about.
That would be a tough one to enforce seeing as how there's probably more access to this than there would be had a single gang box was roughed in.
JAP>
I stated there would be a violation because the box is probably recessed too far back if it remained partially covered.
I can agree with that.This is not a violation at all because there's nothing mounted on the box and the project is not finished yet.
JAP>
JAP>
Kind of hard for an inspector to demand fixing something that isn't done yet. Now if he notices that and asks you what you are going to do with it, he is simply getting a bit of a head start on the final inspection. If this is supposed to be for an emergency light, it either isn't done or they have pretty inconspicuous emergency light installed there.
Try this at your next rough-in inspection, let us know how that goes...
Is this a thing that is critical for a rough in inspection?
Like I said before this must not be a final inspection or else the emergency light should be in place, but is something that inspector happened to notice. Not the kind of thing you ordinarily would make a correction notice for, but maybe something you do bring up just because you saw it, then maybe even make a note to check on it when you are back for final inspection to make sure they didn't try to cover it up and hope you miss it.
There is still time for tile guy to cut it out, lay another course of tile, install an extension ring etc. and inspect again when things are finished.
Jap said it isn't a violation because the job isn't finished. So basically any violations seen at rough aren't violations...the job isn't done. Makes no sense.
I'm simply saying that if an inspector cites a code violation at any point, it's a violation as it stands at the time he sees it. To say anything to the effect of, "that's not a violation because the job isn't finished" has no logic and is irrelevant to the question of whether the work as pictured is code compliant. It wasn't: even if the OP's cited article is arguable or wrong, the box (a 4x4, not a 1g as some have surmised) could not mount a cover, extension or device with only one screw, so 110.3(B) and was obviously set back more than 1/4" (it's set back from both layers of tile...look closely), so 314.20.
..., the box (a 4x4, not a 1g as some have surmised) could not mount a cover, extension or device with only one screw, so 110.3(B) and was obviously set back more than 1/4" (it's set back from both layers of tile...look closely), so 314.20.
I missed any description of what we were seeing and with the fuzzy pic, I thought I was seeing a sideways single-gang ring coming through and then partially covered. I thought the only issue was the partial covering of the access and the crooked and gapped mounting of anything being installed.
Which is the same thing that was said in post #52 but you just don't want to accept it.
The job is not finished so they still can fix the "issue" without jumping into calling it a code violation before the job is even completed.
There is a difference.
Jap>
How did this become a debate over the semantics of *when* a condition is a violation? It's like the electrician's version of the physics problem of Schroedinger's cat.:lol:
