Sierrasparky
- USA
- Electrician ,contractor
is from the administrative code, not chapter 18.
So?
my sorry.
What different does it make?
So?
my sorry.
This is not about semantics it is about the law as written.
The seal says I am responsible for the work.
The law says the finished work must be to engineering standards. It makes no difference if I seal the documents or not.
Been there. Read that. Believe I understand it better than you do, because I am aware of what it does not say. What it does say is to give me my obligations to public safety. I will not seal and sign a document until I am confident that I have fulfilled those obligations. What it does not say is the meaning of the very act of sealing and signing. I’ll address that next.Charlie I think you need to read the code!
Here it is..... Chew on this.
No one, and that includes me, has said otherwise. And the text you highlighted in red in post #35 is the same text that I quoted in post 23.YES it does! you have not read the whole section and directly related ones. By this statute a PE cannot produce knowingly faulty documents.
I am not hiding behind anything. My seal and signature put me at risk of a lawsuit, in the event I failed in my obligations. It puts me at risk because it declares that nobody else is to be held responsible. I did this work, or I supervised this work, so blame nobody else but me. There is no place for me to hide.I am sorry Charlie but you walked into this. I as well as other electrical professionals are just plain tired of PE and EE hiding behind things.
Here is where WA publishes that information:It is about time that we here is the news about some design professional being sued or removed from practice for continued Gross Errors on plans.
And I have worked within that law for the past 18 years. I am fully aware of what it says. I have read every bit of text you have been quoting many, many times over the years. Please don't think you are revealing anything new to us.The law of WA is pretty clear.
It is nothing like semantics. It is, as you pointed out, the law. Other states apparently have different laws. But in Washington State, the law says that my seal attests to the fact that the work was done by me or under my supervision. That is all it says. It is my responsibility to make sure the design conforms to codes, standards, and contracts, before I apply the seal. But when I do apply the seal, all that act says is that I take responsibility for the work.You are foolish if you really think that all the stuff behind the stamp is semantics.
The semantics that many PE play is exactly that, the plans don't need to be compliant for them to sign and stamp them. If they ready for construction they better be compliant otherwise you can face discliplary action as well as a civil complaint as you have stated.
So if you want to go on saying that the stamp means nothing other than the person who signed it, by means please go on saying such. I said my points.
An example for CA. Just because you have a final sign off does not necessarily mean anything these days. Contractors many times do not follow codes or the plans and yet projects are given final. Large projects in my opinion really need inspectors paid on behalf of the owner to scrutinize work.
A bit diverged here.
Charlie's position is perhaps more nuanced than most are used to dealing with. If, within the narrow definition of the law, the signature and seal mean only that the work was prepared by or under the supervision of the signee, then that's what it means. How the PE is to act regarding the execution of his work is covered under other portions of the law and any rules and regulations promulgated by the relevant governing bodies.
what the law actually says is not exactly "nuance" in my book.
Boy,
I never expected this tread to go this way. However it makes perfect sense, in the many years I have seen plans and specifications that blatantly violate applicable codes and standards of the industry. That as long as the PE feels that there is no substantial safety issue. That the PE just is testing the plan checker to see if PE can save the client money.
At this point I say Whatever floats your boat.
I know what is right.
I will try just one last time, as I don't think you are tracking on my message.
I also know what is right. If the plans include code violations, then the PE should be taken to task for it. Absence of a substantial safety issue does not justify anything. If the PE is trying to slip something by the plan checker in an effort to make the client happy, then that PE will have violated the trust imparted to him or her by the licensing board.
All that said, here is the essence of the matter. If something goes wrong, resulting in an injury or property damage, the PE who sealed and signed the plans will not be able to say, “But I just reviewed the documents. They were designed by one of my employees. That person made the error, not me. Blame him.”
Charlie, With all due respect we are just going to have to agree to disagree here. You feel that because the code or statute only says what you think it says and that there is no implied or any other rule applies in conjunction then fine. What I said earlier "what ever floats your boat"
I hadn't noticed any engineers attacking one another. I have noticed a polite disagreement between one engineer and one electrician. But that sort of thing happens on the forum all the time.Wow!!! You engineers really know how to attack each other!
]Wow!!! You engineers really know how to attack each other!
It would be my dream job if, as an “installer”, that you could build the project as per the prints and walk away with everything working as the customer expects it to work. It’s not happened in 20+ years, so I don’t see it changing any time soon. If anything, it seems to be getting worse. So much more responsibility is being put on the “installers” in the field to “make it work”.
That’s just me joining in the rant.
