don_resqcapt19 said:e57,
Yes, but there will be no exposed copper. The solder will coat the copper completely even when it has been tightly twisted.
And what is the danger of 'exposed' copper, especially if it's covered properly with tape?
For an in-line splice, maybe less noise from an "antenna" perspective, or that it is less bulky? Can't see a good reason for a normal joint.lbwireman said:...why (or if) a S&T joint would be preferable to a twisted, crimped (Cu sleeve) and taped one...
But if the joint had an undesirable level of resistance prior to solder - I doubt the solder will improve it by much.... But if it had zero resistance prior to solder the solder will not effect it detrimentally IMO. Meaning... If you have a good mechanical copper to copper connection before the solder - you'll still have the same after the solder.don_resqcapt19 said:e57,
I wasn't really clear. What I am trying to say that with a soldered joint there is no copper to copper connection. There is when you twist the wired together before you solder them, but there isn't after. With a wirenut there is copper to copper after the joint is complete. The small amount of tin and lead between the copper wires is what makes the resistance a very small amount higher for the soldered connection.And what is the danger of 'exposed' copper, especially if it's covered properly with tape?
I didn't say it was a problem...just that it had a slightly higher resistance. Much too little of a change to be measured with any field instrument.e57 said:.... But if it had zero resistance prior to solder the solder will not effect it detrimentally IMO
I've had my xxx confused with a myriad of different things during my life, but never with apple butter. I don't know what the heck that is. But I do know how to solder.And I do know what a good solder joint looks like. The Navy sent me to NASA for a week to learn the science and the art of soldering. They were Very particular there.Back to the apple butter, is that any thing like a hole in the ground?HighWirey said:Anyone who critizes the quality of those pictured solder connections does not his xxx from apple butter.
No contest here that a solder connection is a better, but a more time consuming connection than a wirenut.
I too, did not know that a soldered connection was legal for residential wiring.
And I have heard the term 'solder pot' used. How in the world would a person use a solder pot to complete any joints in residential?
Best Wishes Everyone
iaov said:I don't know what the heck that is.
don_resqcapt19 said:My understanding is that the flux used on the wire before twisting is displaced by the solder and the wire is completely coated with solder in a correctly made joint.
Thanx wirebender. My wife says she ate it as a kid and it was delicious. I'll have to give it a try sometime if for no other reason than to save future confussion on my part.wirebender said:
iaov said:I don't know what the heck that is. But I do know how to solder.And I do know what a good solder joint looks like. The Navy sent me to NASA for a week to learn the science and the art of soldering. They were Very particular there.
growler said:You really can't compare military spec. work ( soldering ) and their strict tolerances to what would be required for residential work.
You are absolutly right growler. And the solder joint that was pictured was fine. I'm sure it would last forever. But IMHO a thing of beauty it was not.There are no "good old days". Just old days and everything we have available to us, wether cars, motor cycles, or plastic gang boxes are better today. I'm damn glad I can wire nut my connections rather than having to solder them!growler said:You really can't compare military spec. work ( soldering ) and their strict tolerances to what would be required for residential work.
Most of the equipment that we use in civilian life ( commercial & industrial ) will not meet military specs. Military equipment must be designed for use in time of war where any sort of break down would be dangerous.
Example" Good resistor for commercial use has a tolerance of plus or minus 5% and a military grade resistor had a tolerance of plus or minus 1%.
People question why military equipment is so expensive but close tolerance work cost.![]()
e57 said:Or electronics soldering to soldering of distribution conductors - two different animals IMO.
iaov said:I'm damn glad I can wire nut my connections rather than having to solder them!![]()
brantmacga said:![]()
yeh. my wife was pulling up the drive when i was taking the pictures.
her - "what are you doing?"
me - "nothing."
her - "doesn't look like nothing. is this for that stupid website?"
iaov said:Thanx wirebender. My wife says she ate it as a kid and it was delicious. I'll have to give it a try sometime if for no other reason than to save future confussion on my part.![]()
