iaov
- Rhinelander WI
Apparently I'm not the only one confused about Applebutter.nakulak said:your wife ate solder ?
Any that I have untwisted have been completely coated with solder, but I have not looked at it with a microscope.e57 said:With the K&T splices I find myself doing all too often - I usually scrape the conductor bare - then splice - then flux - then solder. Just copper to copper as the joint - the flux will flush out anything laying around the splice and allow the solder to flow, but not get between the two (or more) pieces of copper IMO. The copper is usually wrenched tight against each other. I think if you got a cross-section it wouldn't have any solder in between - might need a microscope to check though....
don_resqcapt19 said:Any that I have untwisted have been completely coated with solder, but I have not looked at it with a microscope.
e57 said:The point of contact will be one line for two conductors, at least two with more than two conductors. The idea is to have the length of that point of contact be equal to or greater than the circumference of the conductor. Ideal - would be to equal the area of the conductor. Twist enough to deform the conductor to widen that line all the better.
See attachment:
480sparky said:Not circumference....cross-sectional area.
RHJohnson said:I am sure you really knew where the other end of that wire was before you took all that time to s & t... I found lots of mistakes with wire nuts connecting the wrong wires.
e57 said:(Whats that number 3.14????*R*2)
e57 said:Flux..... But don't recommend acid flux.
don_resqcapt19 said:e57,
It is my opinion that the solder does not just seal the point of contact, it completely coats the point of contact and is the current path.
e57 said:If you have two metallic items mashed together tight - as they should be - how does it get in there? It'll definately fill gaps yes - but get in between - no IMO.
I'm gonna have to go make a splice and grind it down - or pull it apart.....
Just took a grinder to one - exceptionally difficult to keep the temp down and not re-melt the solder - but in the gaps have solder - between, not that I can see between the wire where they are in contact - if there is it's microscopic....
Not in Sicily! :wink:hillbilly said:By the way.....Pie are not square......Pie are round:grin:
e57 said:I took 3 12's - pig-tailed and soldered it - then ground it down in a cross-section - I did not see any between conductors where there were pressed together. Not saying there wasn't any - but solder even hot is a viscous liquid - but did not appear to get into the flatened areas where the conductors where pressed by twisting them together.
Thanks Larry. You just blew my diet.LarryFine said:Not in Sicily! :wink:
