dduffee260
- Texas
I hope the metal bushings have an insulated insert as that is required.
Yes, we use insulated bushings on this.
Yeah those metal bushings with the plastic insert that nose of the condcutors rips out when it comes through the bushing. :roll:
That does happen often it seems like. Still we make sure we have a good bushing when we are complete.
Are you installing them for show? I'd rather have them in before I pull to help protect the wire as it's being pulled.
So now you destroy the wire and save the bushing.!!
We usually remove the bushings and reinstall after the pull. If the puller is set up right the wire never really touches the end of the pipe. If not, 90% of the time the plastic bushing will break off.
