zbang
- Roughly 5346 miles from Earls Court
Coming in late to the party:
Part of my problem here is that the conductors definitely do not pass through the post (unless you drill a hole in it...), nor, one can argue, do they supply or serve the post. Seems simple...
225.31 Disconnecting Means. Means shall be provided for disconnecting all ungrounded conductors that supply or pass through the building or structure.
225.32 Location. The disconnecting means shall be installed either inside or outside of the building or structure served or where the conductors pass through the building or structure.
