DeltaFarce
New User
- NJ
AFCI's save jobs and lives.
Mr. Kirchoff's rules apply even to a one load series circuit, you just don't need to use them for analysis.
But, yes, the service neutral can be elevated from ground enough to cause carbonization even though the service line wires are open.
Simplest example is a duplex with one drop and two meters and an open POCO neutral upstream.. Opening one main leaves both neutrals hot.
(I think I saw the same video you did.).![]()
Use a current limited AC supply with an inverse time characteristic, not a direct line supply. A resistive or inductive current limiter might inhibit the pulse of current associated with a micro arc. A series capacitor might work.Can anyone think of a safe way to do a test applying 120V through either old or new construction-grade softwood?
400 or 500 uA (yes MICRO, e-6 amps) is sufficient to cause tracking to start and tree on any surface, even Teflon, glass, and glazed ceramic. Have run tests on everything from Torlon and Teflon to glass and bakelite and even wood.
Basic process is that the conductive moisture film (even condensed fog) on something like TFE or polyimide conducts a few hundred uA when there are any contaminates. When the film breaks on something hydrophobic like TFE, or a section dries out like on wood, the first point of the high resistance current break arcs and carbonizes a tiny spot. This spreads on repeated wet dry cycles. Can take months or years for 120V in a seldom wet environment, at 480V where there is fog it can happen in weeks. Testing where a continuous spray and dry cycle is applied, the time to track between cm separations at 500 Vdc is only minutes. Faster above paschen minimum voltages.
On materials like glass and Teflon, the surface is just etched and no carbon path is created, just craters for more contaminates to collect over time, which may have organic materials that can create a conductive path (typically years). Any organic insulator will track. An IEC test for this is comparative tracking index, CTI.
Listen here. I am probably the best on my block when it comes to electrical stuff. Maybe even my entire neighborhood.afci's are completely irrelevant to the topic
~RJ~
There is one very big difference to your analogy.Listen here. I am probably the best on my block when it comes to electrical stuff. Maybe even my entire neighborhood.
AFCI's are today's seatbelt. There were passive restraint system haters back then just like there are AFCI haters today.
The people who put AFCI's in code are infallible. They wouldn't have made AFCI's a code requirement unless they were absolutely, positively, 100% perfect and ready to save lives.There is one very big difference to your analogy.
Like them or not, seat belts work. And they work better than previous alternatives.
They shut down arcs where they live.In a perfect world where benevolent souls are the norm, and who knows maybe the NFPA is.
But, explain to us who are not as smart, how do AFCIs save lives? What are the mechanisms of action behind that?
