RustyShackleford
- NC
- electrical engineer
Thanks, Frank. Yeah I guess maybe supplemental isn't the right term - but just in the sense I have a perfectly good 50gal unit that can handle the whole house, but choose to add the 10gal unit, figuring it'll definitely add convenience of quicker hot water, and hopefully be at least a break-even on efficiency (with savings from avoiding "stranded" hot water cancelling out the tank's standby losses).If you feed it cold water, it is NOT supplemental, it is the hot water source for your kitchen sink and dishwasher.
If you have a new energy efficient dishwasher, that should be enough water to feed it, and the dishwasher will heat it the rest of the way depending on cycle you choose (regular, sanitize, etc). Might not have any hot water for hand washing items (pots/pans) at the same time. Only time will tell. That and how many people will be using it. The chart for reheat times in on the Bradford-White website. If you are in an area that always has 65-70 °F water then you are quicker than us in the winter with 40-45 ° water.
You might set that thermostat to any temperature you like, but if over 120°F, scalding is a real threat. I know, I grew up in a house that had 160 °F water. One of my earliest memories is getting burned by water.
Bradford-White go the voltage right, just not the wattage. Twice as slow to recover at 1500 W.
I think the dishwasher uses only a couple of gallons at startup, so you've still got at least 5 minutes of handwashing out of a 1.8gpm faucet (with some cold water mixed in). I keep main unit at 120 degrees or so, but figure scalding is a much smaller risk in the kitchen (you're only exposing your hands, not your entire naked body); so maybe go with 140. And my incoming water is pretty close to 60 degrees.
But, if I'm all wrong, I feed the thing with hot water. That's the beauty of PEX (which I'm just discovering); I like it - it reminds me of wiring.
