CarlCaliente
- Katy, Tx. USA
I've run into a problem. So, we've installed runs using rigid conduit that does not exceed the 360 degree rule, but at the ends of the conduit we have changed over to sealtite due to the inability to make the proper bends in rigid. The inspector says that we are over our bending requirements. I assumed that you can use the sealtite connectors in lieu of a pull point according to 310.15 (F) One run is 360 degrees of rigid and 180 degrees of sealtite. Am I incorrect in my assumption and interpretation of the code?
