- Chapel Hill, NC
- Retired Electrical Contractor
On a dead end 3 way we use the white as a traveler. I see no issue with it as long as it is reidentified.
Yes.The NEC makes the rules for conductor colors in cable with attention to how cables are made. We would need cables with no white conductor to never have to use white for ungrounded conductors.
Is it legal by code to use red and white as travelers on a 3 or 4 way switch?
Do not use white. Who cares if it's code or not. There are a trillion feet of white wire in the field using it as a neutral and I for one would want to open any box in the Country and expect white not to be a traveler.
We always used orange for travelers and switch legs until they stopped us because of the hi leg orange issue. I would say white is a no-no as more of a best practice installation.
It'd be hard to find NM with orange travelers.... You can tell this is a Resi post and they're talking about NM, not individual conductors.
JAP>
I'm a pipe and wire guy also, but, the Residential side use NM, which confines them to Black, Red and White.
They're installs are much more confusing for that reason, and, they are under much more strict rules than the commercial and industrial world is.
JAP>
Ok, if he is running romex, why is asking if he can use white? Yes, they have no choice but to re-identify. Is the answer he is looking for, how to identify a white, or, can he do it by code. He wants to know if it's legal by code. If I'm running romex, I would already know that question.
I pity these poor guys that have to run romex. We pipe Jockeys had it a lot easier.
But, If I started running romex, I would least try to identify the whites if they were using them as hot or travelers. I build my jobs based on how a maintenance electrician would have to maintain my installations, 20 years later. He should be able to open a box and have a clue what I was thinking and how I ran the pipe or romex, not some snarled up mess that takes Einstien to figure out.
Because on this forum there are several different calibers of electricians.
Some just starting out, some been around forever, some residential, some commercial, some industrial, and, depending on what part of it you were brought up in, makes all the difference as to just how much you may, or may not, know.
JAP>
I've done both. Started out in industrial, didn't touch NM aka Romex until the economy turned 6 or 7 years later. Totally new learning experience, but I am glad I did it. For the same $$, I'll take nice clean NM over pipe and wire any time, but I do like running pipe and have to say it's more fun. With the exception of re-mods, residential NM work is easy and clean. Learning how to wire lights with NM isn't rocket science. After 2 or 3 houses, it's no problem at all for the most part.
I have walked in some houses with the rough done just before sheetrock and sad; Did Leonardo Da Vinci do this? Pure artwork. It's a lot harder than people think it is. The pipe guys can rip in or out wire at leisure. These guys need to get it right the first time. And, they are limited with the colors they can use. I bow to the Romex guys and give them a salute of skills that not all of us have...
Gary
After spending years doing both pipe and 'Romex', there is no art in running 'rope' (Romex) compared to putting in a nice looking pipe run. As the owner of two Chicago benders, I can make some pretty nice looking pipe runs. Even with a hand bender. You are overestimating the task of Romex work.
When I first went from industrial pipe and wire to doing residential work, I remember getting scolded by the boss for spending too much time making sure the holes in the rafters were perfectly lined up. He wanted fast, not pretty.
