Good lad! Well done!
You have finally taken note of what I posted in #6 on the first page of this thread.
Your point is entirely different: it is about increasing the core size for use of 60hz transformer on 50hz; mine is about keeping the same core size for the same purpose.
To keep the flux density the same. Flux is dependent on the volts times time. At 50Hz the volt second area for any half cycle is 20% greater than at 60Hz. So, for the same flux density, you need 20% more core.
Here the discussion is whether the use of 60hz transformer on 50hz is possible in principle.But not a lot of good if you wanted what the transformer was designed to give - 480V output.
To exemplify how specious your point is, you could use the transformer with 115V into give 4V out.
