jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
Gets discouraging to see all the garbage people do. If someone knows how, I don't fault him for doing something. But too many people think they know more than they do. I've actually seen a few homeowners who had done extensive work & done it well. Such details as pigtailed receptacles, wired to screws, not backstabbed, securely mounted boxes, taped switches, etc.we have had licensure here since 1915 and there is still unlicened work going on.
my aunt call the other day because she had pipes leaking in the basement she hired a "handyman"to remoldel her first floor bathroom he does it all
well he cut the pipes for the sink and the shut off valve at the water meter did not close all the way so the water was coming out slow but was flooding the basement he walked out:-?
So she called me to fix it. I said you need a licensed plumber.
so i drove over to see and the valve woul not close i called my plumber he came right out and fixed it in two seconds it seemed like.
Well the handy man not only did plumbing but Electrical too not only did he rough the bath room he did a service upgrade while he was at it from a 60amp fuse box to a 200 amp panel.
no ground rods and he re-used the #10 solid ground wire bonded ahead of the
water meter .
the plumber call the plumbing inspector and i called the electrical inspector and had him come out.
Mr handy man has some rough sea's ahead:grin:
