According to switchgear instructions i have never noticed that it can only be operated by qualified persons??  It is designed to operate without danger to it's operator.  Where the problem arises is when operators are not properly instructed in the proceedure to reset a breaker and/or to contact a pre-determined qualified individual with any questions or concerns that might arise.  Like trying to close a pringle switch with a blown fuse or ground fault trip!  And of course knowing how to operate the basic switch.  The manufacturers have pictures along with instructions and they still can't get it right....
From Sq-D masterpact switchgear instructions, page 4
"Electrical equipment should be installed, operated, serviced, and maintained only by qualified personnel. No responsibility is assumed by Schneider Electric for any consequences arising out of the use of this material."
And on page 13
"HAZARD OF ELECTRIC SHOCK, EXPLOSION OR ARC FLASH
? Apply appropriate personal protective equipment (PPE) and follow safe electrical work practices. See NFPA 70E.
? This equipment must be installed and serviced only by qualified electrical personnel.
? Turn off all power supplying this equipment before working on or inside equipment.
? Always use a properly rated voltage sensing device to confirm power is off.
? Replace all devices, doors and covers before turning on power to this equipment.
Failure to follow these instructions will result in death or serious injury."
I could go on and on with the warnings throughout this manual, and could find the same warnings from any OEM.
