Re: Resistance Cube
Actually, I want to change my first guess. At a closer look, I have determined there are 3 resistors in parallel that are in series with 6 more resistors in parallel that are in series with the remaining 3 resistors in parallel.
Based on that, the resistance between the two points will vary. When all is said and done, I beloeve the answer is: RT= 5R/6
