Re: Restaurant POS...
Check out www.powervar.com. It looks like they are basically isolation transformers. (I'll be Square D wishes they could sell 360VA worth of transformer for $1700!!)
The voltages the tech measured were probably "high frequency noise" voltages. You can't measure that with a DMM.
Steve
Yes, the general rule is "One and only one" neutral to ground bond.If indeed there is a neutral-ground bond at the service disconnect, then should the neutral be separate, "floating", from the equipment ground in the panel?
Steve
