Retrofit Kits and Air Handlers
shinkle
New User
Glenside PA
I have a fixture that has the following condition. The fixtures have air return on one end and the ballast enclosed in a compartment on the other end. The cover for this compartment holds the old tumbstones and must be removed thus exposing the ballast. I would actually like to mount the ballast on the top center of the fixture under the reflector if not an issue?
GoldDigger
Are you saying that these fixtures are deliberately connected to an air handler with flow through the fixture for energy efficiency purposes?
If so the wiring would have to be plenum rated unless separated from the air flow space.
Would your proposed change defeat that separation?
Gregg Harris
Virginia
It sounds as if he has a troffer fixture used for air distribution in commercial application.
GoldDigger
I was thinking the UV light in the air handler setup.
Somehow I do not see retrofitting the UV light with LED or HO fluorescent with accompanying ballast replacement.
I doubt that the ballast in typical retrofit kits is plenum rated though.
Maybe I am reading too much into the OP's reference to retrofit in the thread title.
Gregg Harris
Virginia
It sounds as if he has a troffer light that needs the ballast changed and he wants to "retrofit" the location of the ballast.
