no1uknow
- North Carolina, USA
My question is regarding whether or not the romex in the basement of a residence is in compliance with code. At this residence, Romex (10/2, 12/2 & 14/2) can be found stapled to the floor joists in virtually every direction (parallel, perpendicular, and across at angles). Some of the parallel runs are along the bottom edge, some are along the vertical side of a joist. The floor joists are approximately 9' or so above the floor. The floor joists support all fresh water, septic, and LPG piping, as well as AC duct work.
A home inspector did not note any anomalies with the electrical system (except one missing face plate) or otherwise gross or negligent violations. Dwelling was built in 2003. It has a full size basement which is somewhat unusual in central NC; the property is sloped in such a way that the ceiling at the front of the basement is just above ground level, while the floor of the basement at the rear of the home is at ground level. It shares space with a two car garage, water / AC closet, stairway, and a small finished laundry room where the main panel and SE is located. It has a solid concrete slab floor and cinder block walls along the front and sides, while the rear wall consists of more common materials (wood, siding). The exterior face of the cinder block, the portions below the soil level, are sealed and insulated on the exterior side. There is no water or moisture issues, and it is never damp.
Since I am new to this forum, I will tell you that most of my experience and knowledge comes from industrial situations where rigid or EMT is virtually always used. Most of it is for production machines and equipment. Occasionally I will run power to switches, receptacles, emergency lights, etc. but again this is always done with conduit and in the industrial setting. I've done many electrical installations for panels, transformers, conduit, etc. over the years and I know code is different for residential, which is why I'm asking here to clear a few things up :blink:.
Thanks is advance.
Thanks is advance.
