Took one of there reactors offline 1:00 this morning because pumps weren't available.
Anyone have anything on this? This one is in my backyard. Apparently there are issues at New York’s 9 Mile Point, Oyster Creek, Indian Point and, Limerick as well?
Anyone?
Salem Unit 1 was manually shut down by plant operators at about 1:10 a.m. Tuesday as a result of circulating-water pumps being affected by high river level and debris in the waterway. The circulating-water system is used to cool down steam generated by the reactor; it is a closed system that does not come into contact with any radioactivity.
Nine Mile Point 1 underwent an automatic shutdown at about 9 p.m. Monday when an electrical fault occurred on power lines used to send power to the grid. It is likely a storm-related event, but the plant’s operators are still evaluating the cause. All plant safety systems responded as designed and the shutdown was safely carried out. Meanwhile, Nine Mile Point 2 experienced a loss of one of two incoming off-site power lines as a result of the fault. One of the plant’s emergency diesel generators started in response to generate power usually provided by the line. Nine Mile Point 2 remained at full power.
Indian Point 3 automatically shut down at about 10:40 p.m. Monday in response to electrical grid disturbances caused by the storm. All safety systems responded as designed and the unit was placed in a safe shutdown condition.
At Oyster Creek, the Alert was declared at approximately 8:45 p.m. An alert is the second-lowest level of emergency classification used by the NRC. The Alert was preceded by an “Unusual Event” at about 7 p.m. when the water level first reached a minimum high water level criteria. The water level rose due to a combination of a rising tide, wind direction and storm surge. Oyster Creek was shut down for a refueling and maintenance outage prior to the storm and the reactor remains out of service.
No issues at Limerick that I have been notified of, however theydo have a team from the NRC on site as a precaution, as all the plants in Sandys path have had since Sunday.
