Schedule 80 bell end
infinity
New Jersey
Journeyman Electrician
I took a quick look through a few catalogs and found only SCH40's. Is a SCH80 fitting required or will a SCH40 work?
Cow
Eastern Oregon
If you're concerned with that shoulder at the end of the conduit, they make pvc conduit reamers that will put a chamfer in the end of the conduit, just like the larger sizes of pvc come with from the factory.
Fulthrotl
~Autocorrect is My Worst Enema.~
truth is, a small router with a 1/4" radius ball bearing cutter could be used
to dress the end of large pvc, accomplishing the same thing as a bell end,
but it isn't listed.....
kwired
Electron manager
NE Nebraska
Back side of a razor knife works very well. Used it for years.
I do that even just when transitioning from sch 40 to sch 80.
Used to just ream the ends when ending the raceway like in the OP or for transition to direct buried conductors, but anymore they don't think that is good enough, we need to buy a fitting for the purpose.
JJWalecka
New England
Yes that shoulder that is shown in the picture. I was curious if a schedule 80 bell end fitting would eliminate the need to ream the PVC out.
FionaZuppa
AZ
Part Time Electrician (semi retired, old) - EE retired.
+1 for using router to chamfer sched-80 ID edge before gluing the 40 bell on.
FionaZuppa
AZ
I am more likely to have a RMC reamer handy then a router.
ryobi p600 cordless can be had for ~$9-$40. a tool like this can be used for more than just chamfering of plastic tubes :thumbsup:
Smart $
Esteemed Member
Ohio
I've not tried it but perhaps a unibit and cordless drill may be handier. :D
Physics will likely require both hands on the drill motor. Being safe will demand it. :happyyes:
kwired
Electron manager
NE Nebraska
That does work, but I don't have a bit large enough to do this with conduits over 1 inch trade size.
Smart $
Esteemed Member
Ohio
It doesn't have to fit the hole. Just run it around the ID like a powered rasp. Heck, for that matter, even a standard drill bit may do the job... but the taper will be [more] freehand.
iwire
Massachusetts
I do what kwired does with up to 1" but I think if you tried to use it like a rasp on larger pipe you would spend more time failing and swearing than just grabbing a rasp.
