stickboy1375
- Litchfield, CT
electricalperson said:not quite sure what woodhead is slang for, but i install a GFCI, bell box and a bubble cover
You ever have any problems with corrosion with that type of setup?
Woodhead is a brand, popular with shore power cords. The cord cap actually "seals" into the cover, barring the entrance of moisture and condensation. The Leviton "Wetguard" series is pretty much the same.electricalperson said:not quite sure what woodhead is slang for, but i install a GFCI, bell box and a bubble cover
Wow, they've got the pump controller in the box too.stickboy1375 said:I keep everything outside of the tank, I'll bury a groundbox next to the tank and install my receptacle inside of that, along with the splices for the alarm float... Kind of like this setup
i never had any type of corroson i use silicone in back of the box and where the wires enter the box and its up high right below the lidstickboy1375 said:You ever have any problems with corrosion with that type of setup?
i never seen that before it looks like a better way of doing it. next time i do one ill try to get my hands on one of thesestickboy1375 said:I keep everything outside of the tank, I'll bury a groundbox next to the tank and install my receptacle inside of that, along with the splices for the alarm float... Kind of like this setup
electricalperson said:i never had any type of corroson i use silicone in back of the box and where the wires enter the box and its up high right below the lid
After there's poo in there, that becomes the plumber's job. :grin:stickboy1375 said:The corrosion would be at the plug... but how many electricians ever go back to change a pump out years later...
ive changed my fair share of bad septic tank pumpsstickboy1375 said:The corrosion would be at the plug... but how many electricians ever go back to change a pump out years later...
stickboy1375 said:Who was enforcing that one? Sounds like another xxx xxxxx requirement... :roll:
marcerrin said:I use direct burial splices inside the tank and extend all the leads with UF, inside a conduit, back to the house where usually there is a "rhombus" box, or some other controller that I make all connections in.
I was asked to use explosion proof fittings once, I appealed, and won. Duct seal is fine.
stickboy1375 said:That seems like a pain for servicing, plus all the pumps I do are piggyback with the start/stop float....
frizbeedog said:When I run into a piggyback, I cut the plugs from the the cords. Route the cords out the side of the tank riser, install a 10" round ground box flush with the tank lid. Run the circuit to the ground box and install a disconnect within site cause I cut off the disconnect in step one. Disconnect usually at the house.
Don't know about listing, but I'm pretty sure it would void the warranty.stickboy1375 said:I dont think your allowed to cut plug off... Isnt that pump UL listed with it installed?
electricman2 said:Don't know about listing, but I'm pretty sure it would void the warranty.
