Service Rated ATS-No Generator
Next topic then
Next topic then
If we forget about the load for a moment, what became of the original answer of utilizing an ATS in manual mode.
just curious...
just curious...
If you have manual transfer equipment then the loads will be selected by the end user as you would with an inlet and a breaker interlock.
just curious...
So far it's been established that it's likely permissible due to the ATS being capable of operation as a manual transfer switch.
I will only say it is much easier to use an ATS as a MTS then it is to rig up some actuators, backup control power supply, and controls to be able to use a MTS as an ATS.
Whether either can be done in compliance with codes....
