steelersman
- Lake Ridge, VA
gotcha. I think.76nemo said:I know, just :grin: :grin: :grin: 'ing.
And maybe you should read my post again.steelersman said:You are wrong also.
If you actually bother to look at the entire presentation you will see that it does turn into a series circuit by opening the neutral. So maybe you should go back and look again!![]()
man you are strange. Have you ever taken any classes?Besoeker said:And maybe you should read my post again.
As drawn in the presentation, it is just the neutral to ground link that is removed. That does not change the arrangement into a series circuit.
It is still shown as a 120-0-120. It's only when you remove the supply neutral that it turns into a series circuit.
Is that a more lucid explanation?
:smile:
so you think the PPT presentation is incorrect? You don't think the circuits are in series once the ground/neutral connection is removed? You don't think the two devices will have different voltage drops accross them? You think that Ohm's law isn't true or correct? What are you actually saying then? Maybe you should be a little more clear then and say what you mean instead of the opposite.Besoeker said:Although it says that in the PPT presentation, it isn't shown as a series circuit.
For it to become a series circuit, the supply neutral would have to be disconnected.
Normally, there should be current flowing in the neutral to ground connection so opening it would have no effect on the distribution of voltages round the circuit.
What is your opinion of the facts Bob? Is the PPT presentation correct or incorrect? Is the circuit now a series circuit once the ground/neutral is removed? It's not about agreeing or disagreeing. there is only one correct answer and I'm trying to get him to understand it.iwire said:Agree or disagree but either way keep it respectful.
steelersman said:What is your opinion of the facts Bob?
fair enough.iwire said:I have not been following the thread at all.
Thats great, but try to find a way to do it without calling him strange, or questioning his education just because he does not see it how you see it. :smile:
As shown, the neutral isn't removed.steelersman said:so you think the PPT presentation is incorrect? You don't think the circuits are in series once the ground/neutral connection is removed?
the ground symbol is used as the neutral. It also uses W where it should use the symbol for ohms so you could say that it's just another misprint but the logic is still there and correct.Besoeker said:As shown, the neutral isn't removed.
Just the ground.
The ohms symbol shows up just fine for me.steelersman said:the ground symbol is used as the neutral. It also uses W where it should use the symbol for ohms so you could say that it's just another misprint but the logic is still there and correct.
But where does your neutral end up at?Besoeker said:The ohms symbol shows up just fine for me.
And ground isn't the same as neutral.
I see that you were able to correct it for the ohms symbol and the neutral with a line pointing to it. Lol. Awesome! The neutral has no connection in this pic. It is open. Now they are in series. Now the current stays the same for both. Now the voltage changes for both. Now the power changes for both. Bye.Besoeker said:The ohms symbol shows up just fine for me.
The center point of the supply, of course.steelersman said:But where does your neutral end up at?
steelersman said:I see that you were able to correct it for the ohms symbol and the neutral with a line pointing to it. Lol. Awesome!
The neutral isn't open, though. It goes back to the supply. That's the point.steelersman said:The neutral has no connection in this pic. It is open.
Besoeker said:The neutral isn't open, though. It goes back to the supply. That's the point.
Thanks Bob. Finally someone else chimes in to back up the facts! For that I might change my avatar just for you.iwire said:I looked at the power point presentation.
I agree with steelersman, the neutral has been opened, and in the image you posted it is OPEN.
Watch the presentation from the start and you can see the neutral ran all the way to the 'Dot' that the ground is connected to.
The round black 'dots' are the supply in this circuit, the neutral has been removed from that black dot so it is open.
steelersman said:Thanks Bob. Finally someone else chimes in to back up the facts!
The diagram shows that the ground connection has been opened.iwire said:I looked at the power point presentation.
And then it stops short of the dot but is still connected to both loads.iwire said:Watch the presentation from the start and you can see the neutral ran all the way to the 'Dot' that the ground is connected to.
Besoeker said:The diagram shows that the ground connection has been opened.
