170617-1336 EDT
Smart $:
If you have no equipment and experiments to prove what you say, then how can you back up your statements?
Well, there you go. I guess you either have to take my word for it... or not. It seems you are not. So I guess we're at an impasse.
I doubt that you have an educational background in electrical engineering. This probably means you have not studied differential and integral calculus, differential equations, AC and DC linear circuit analysis, AC and DC machinery, magnetic circuits, semiconductor devices, and instrumentation. You also may not have run a lot of experiments in these areas.
Hey! At my point in life, the only people that have educational backgrounds are people that stayed in the educational system for a lot longer than they were there as a student. The last time I saw the inside of a classroom as a student in that system was 40 years ago. Our culture was barely into the IC chip and the campus computer was a mainframe with data terminals that took up an entire building. My field was electronics.
From there I could tell you a story about how life off campus takes our knowledge and experiences down different paths... but instead, I'll shortcut it by saying all that matters is I'm here having a discussion with you about concepts that aren't seen matter of factly by what? ...say 99.99% of people out there. What does that mean to you?
Making the statement that a black box (in the case discussed earlier, just diodes) with no reactive components will reflect the power factor of the load back to the input of the black box makes no general sense. An ideal transformer would reflect the PF, but any linear element, resistive or reactive, or any nonlinear element, would not reflect the PF.
When you do not understand how something works (details), then it is not very feasible to predict how that something works under various conditions.
I have another black box. It improves the power factor of a motor load to near 1 (assuming it was chosen wisely
) with insignificant distortion as measured at the input. All my black box contains is a capacitor bank.
What device other than a capacitor can improve power factor locally? If we discuss it conceptually, a power source or storage device that can reflect the reactive current of the motor. VFD's have none other than its filter caps. Take away those filter caps and the reactive current of the motor has to be handled somewhere. That's why power companies charge some customers extra when they "use" too much.
I have created some more experiments to illustrate some points. One shows the input current to a HAAS CNC mill vector drive, and it is nothing like a sine wave that it would need to be to obtain a good power factor.
I've never really thought of power factor as requiring a pure sine wave to achieve a 1. Considering the voltage is sinusoidal it is a common error to think the current must also be sinusoidal to get a power factor of 1. I've only ever thought of it as a number which corrects for V*A appearing as more power than is actually being used.
Anyway... I have other matters of life to attend to now, but I'm around to continue the discussion however it unfolds...
