wwhitney
- Berkeley, CA
- Retired
As you already know since you've put Desmos into degree mode, you switch between degrees and radians via the bottom of the menu you get from the wrench icon on the upper right. Either way in Desmos you write sin(x). Since my typing doesn't have a little toggle switch, I'm going to write sin(x) for x in radians, and sind(x) for x in degrees. When you see sind(x), you just make sure Desmos is in degree mode and enter sin(x) into it.Desmos does not like sind, or I don't know how to use it.
No, you're again entering a formula for Green that is the wrong formula and would be assuming the answer anyway. Start with what you have correct (now I'm writing sin(x) instead of sind(x) since we're specifically talking about Desmos in degree mode):But, I did take the point by point addition of A-B and B-C, determined the 60 degree phase shift between the two, used -30 to get the correct position, and added in the 294.449 peak of 208. Does that green line not represent the combination of A-B and B-C voltage waveforms?
Black: y=170sin(x)-170sin(x-120)
Red: y = 170sin(x-120) - 170 sin(x-240)
So to get Red-Black, enter the formula
Green y = (170sin(x-120) - 170sin(x-240)) - (170sin(x)-170sin(x-120))
If Desmos has a way to refer to the y values from a previous line, you could just enter
Green = Red - Black
for the appropriate syntax of Red and Black, but I don't know if it has that feature or what the syntax is.
Then the Green function is the actual difference of the Red and Black. But if you enter a new formula, not sure what color Desmos will use, but maybe it's Blue:
Blue y = 510sin(x-120)
Then you'll find that Blue and Green coincide. Which is a graphical proof of the statement in post #319 (with an extra factor of 170 everywhere).
Cheers, Wayne
