mivey
crossman said:I think that the electronics gurus would be perfectly happy with the following diagram and the use of the centerpoint as a reference for all voltage measurements. I think the math and current flow and analysis still works.
Crossman chose a battery symbol but his point would be the same if he started with a center-tapped transformer and fed into a rectifier and voltage regulators to make a +/- supply.johnny watt said:I suspect that the electronics gurus would call that diagram a two voltage supply not a split voltage supply.
Not exactly. In the 120/240 single-phase case, it really IS the neutral point for the single phase and can be used as a reference point (but it is NOT the neutral point for the 3-phase delta).gpedens said:Since n is in the middle it will be negative to 1 but positive to 2. The terminal "n" is not really neutral or 0, it is simply in the middle.
If it were a 2-wire 120 volt circuit, where do you think the neutral point between the grounded conductor and the ungrounded conductor would be? I'll give you a hint, wire two identical heater coils in series and it should be obvious. As another exercise, take this 120 volt circuit and feed a center-tapped transformer (like you might do to feed some electronics circuit board) and find the neutral point. Once you find this neutral point, you can find a way to supply the circuit board with a + and - supply for the components.
This same 120 volt fed circuit can also be fed with a 240 volt center-tapped transformer. This is the same as what we have in the lighting pot of the delta. We do not have access to the real neutral of the 3-phase delta, although we could create one.
I think he is saying that one goes positive and one goes negative with respect to n. "kick" tests should show that.gpedens said:By saying that V1n and V2n are 180 out of phase to me you are implying that 1 and 2 both go positive with respect to n. Do a "kick" test with a battery on the winding and you will see that that is not the case.
You would get the same result for separate cores as rattus said:gpedens said:Its only one winding or 2 halves) on one core, only one voltage is induced. We choose to split it for convience
rattus said:The voltages could come from separate separate transformers, separate generators, or a black box for that matter.
