mivey
Can I get in on some of that? I had a long day and am in need of a boost of self-righteousness. Smart $, you were just sooooo wrong. Thanks, I needed that.Smart $ said:...Perhaps you should should state it a few more times if you haven't quite reached that plateau yet...
Back to topic:
Carl & Jim, I was at Ga Tech today and was perusing some of the reference material at the bookstore. One of the books mentioned that single-phase was one voltage source supplied on two wires. The author also called two sources at 180 degrees two-phase (as well as the 90 degree stuff we already know about). I did not buy the books ($160+ for the set...I miss being a student...NOT), but it made me think about something.
You have mentioned in the past that the center-tapped transformer with a neutral reference really was just one source and should have the phasors drawn in one direction.
You may have already mentioned this in the past but do you see that it would make any philosophical difference (in your opinion of course) if the voltages were supplied by two different generators? Suppose they were mechanically tied or synched so that the waveforms looked exactly the same as the waveforms obtained by the center-tap reference. We could still get a 240 volt waveform like with the single winding.
In the center-tapped case, we start with one voltage and "split" it into two voltages. In the 2-generator case, we start with two voltages but combine them in series so we can mathematically sum them to one. Would you still take issue with phasors with a 180 degree difference? Would it matter if it were feeding the most complex load you could imagine instead of the original simple resistor circuit?
Just trying to clarify your opinion in my mind. Thanks
[edit: 3-wire supply, of course]
