 - Chapel Hill, NC
 - Retired Electrical Contractor
I would also bet if you wrote a proposal to clarify this it would be rejected on the basis that the code already states what you are trying to say.  They may even laugh at it..
			That's half the problem with half the Code*.I would also bet if you wrote a proposal to clarify this it would be rejected on the basis that the code already states what you are trying to say. They may even laugh at it..![]()
99.99999% of the problems with the code could be resolved if 90.1 was strictly followed.That's half the problem with half the Code*.
It is not clear and concise, while CMP members consistently claim otherwise when clear and concise proposals are made.
*For those technical gurus out there, yes, that is one-quarter of the Code not being clear and concise. So...
DISCLAIMER: Quantitative association is for effect only and not intended to be an accurate quantitative reconciliation.
Just curious... aside from the apparent prohibition, what are your reasons why such a receptacle should not be allowed on an SABC?I agree there are issues with the code however this issue is pretty clear to me. So a receptacle inside a cabinet is not compliant for the required outlet but one that is behind the same door with a bigger cutout in the back would be considered outside the cabinet and then satisfy the requirement. You would never get that by around here nor should it pass anywhere.
I never said you did.I never said that they shouldn't be allowed. .... I know the NEC does not allow it and that is what I am addressing. That and the fact that the receptacle is within a cabinet if it behind doors regardless of how the back is cut out
That is he way I took it...:thumbsup:It appeared to me you were implying so.
You guys must be married... because you always interpret everything stated has some ulterior meaning.That is he way I took it...:thumbsup:
You guys must be married... because you always interpret everything stated has some ulterior meaning.![]()
seems to assume I have reasons why a receptacle should not be allowed...what are your reasons why such a receptacle should not be allowed on an SABC
I don't think so...How about this? Since I already have the two SABC requirement met can I the additional circuit a microwave circuit and add a countertop receptacle on the circuit as long as I have another receptacle in the 24 inch counter area fed from one of the SABC's? It's pretty much the same thing except I have a receptacle on a microwave circuit instead of a "SABC".
Leaving off part of a sentence can make a big difference. The gist of a sentence requires the entire sentence be considered. The part-left-off's intent was noting I understand your position is driven by your assumption of Code intent. The latter part then means, do you have any reasons other than that.Yeah but this
seems to assume I have reasons why a receptacle should not be allowed...Just curious... aside from the apparent prohibition, what are your reasons why such a receptacle should not be allowed on an SABC?
And there you have a prime example of the difference between intent vs. clear and concise... on both accounts... :thumbsup:Yes but if you had said "Do you have any reasons other than that." it would have been clear-- It just was not clear to at least two of us- and no we are not married yet.. I am still courting...![]()
