ramsy
NoFixNoPay Electric
- LA basin, CA
- Service Electrician
Ceiling fan type speed control cuts a capacitor in line.
Variable type like the specific model I mentioned is intended for a wider range of fans, including exhaust fans. What did Lutron say?
You are correct.
Lutron has a 2-Amp fan-speed control that uses capacitors, rather than voltage regulation.
Lutron single pole, 120 V / 2.0 ASFSQ‑F‑HO is a 3-speed fan switch, not stocked in stores, and not tested with my 1600 RPM fan, but self testing is possible at the fan's highest setting only.
If special ordered, testing may determine if Lutron's control is slower than the built-in 3-position switch of 1600, 1450, & 1100 RMP.
VFDs for Permanent Split Capacitor motors exist, but will likely cost you more than a new fan with speed control included. But if you persist in doing this, in the US you can buy them from a company called Bardac. They are made by a U.K. company called Invertek, but they are only sold through brand label agreements like Bardac here.
What are you looking for? Looks like the unit already has three forward and three reverse speeds from the control mounted on the unit, which is likely switching three different capacitance values into one winding to get different torque value out of the motor at each speed.Thank you immensely, will ckeck out Bardac.
Perhaps for tomarrow, I should also ask if a another type of 120v reversable fan is better suited for simpler speed controls?
By slowing it down you are effectively making it a lesser fan and may not meet your goals of cooling dwelling down once you slow it down enough to meet desired noise level.Correct, the built-in 3-position switch isn't slow enough, too noisy & overkill for simple circulation when dwelling is empty.
SPEED, HIGH, MED, LOW
....CFM 3560, 3120, 2510
....RPM 1600, 1450, 1100
When dwelling is occupied, lesser fans had failed to keep it cool during hot days, inadequate CPM.
Yes, the more painful the lesson learned, the longer it will be remembered.If that is the case you need a different fan design.
