code_compliant said:Just out of curiosity, where do the service entrance conductors go? It doesn't look like it 90's out above the sill plate.
acrwc10 said:I can't see that close in, is there a main disconnect?
mdshunk said:Gas pipe in the working space is the only thing I don't really like in that pic, but it looks much more modern (maybe even brand new) when compared to the Pushmatic panel. The biggest tragedy I see hasn't really happened yet. I see that the quality Pushmatic equipment is soon going to be replaced with some Homeline junk.
code_compliant said:Have you got pictures of the final product?
frizbeedog said:Around here the violation would be the meter in the basement. Every time I see one of you guys post a pic with a meter in the basemet.......
Do the meter readers have keys to every house or do they have to make an appointment with the homeowner to read it?:-?
That appears to be an AMR meter in the pic, but yeah, they often do have keys to the homes. My former home had the gas meter in the basement, and if I was home, the meter reader would basically just come on in the house that was normally unlocked, holler "Meter reader" and trek on down to the basement. Freaked my wife out every time.frizbeedog said:Around here the violation would be the meter in the basement. Every time I see one of you guys post a pic with a meter in the basemet.......
mdshunk said:I see that the quality Pushmatic equipment is soon going to be replaced with some Homeline junk.
Is that an electrical poltergeist in the pic??:smile:480sparky said:Usually, the POCO here will read the meter once, maybe twice a year. They extrapolate current usage based on prior years.
Some meters are capable of sending an RF signal to a passing meter-reading truck, but this usually solves the problem:
You mean other than the fact that they suffer with a poor bus to breaker connection the same way every other Westinghouse clone does?frizbeedog said:What's the beef with Homeline.
ItsHot said:Is that an electrical poltergeist in the pic??:smile:
frizbeedog said:Pushmatic holds up well. Most of the ones I see are in excellent condition.
On the other hand I know a few people that feel the way you do about Homeline. I use QO Type. What's the beef with Homeline.
ItsHot said:Marc would have painted the backerboard!:grin:
code_compliant said:I think it looks real good. Two questions.
What do you usually do with the old mast?
Do you prefer EMT over PVC? I can't think of the last time I saw a residential service in EMT
frizbeedog said:I'm assuming you tied into the old drop till they swing it, but it's hard to see any wires between the two masts.
