JFletcher
- Williamsburg, VA
What would you use 480V on that only would be supplied by two legs?
480V lighting.
The model #, job# and serial# of the xfmr is the same in both pics; they are of the same unit.
This link:
http://federalpacific.com/training/transformer-basics/chapter-2.htm
may help as might this one:
https://stevenengineering.com/tech_support/PDFs/55MAIN.pdf
which says an xfmr this size can be reverse fed.
winnie, where is the high side center tap? I dont see it and the schematic appears to show one primary/high side coil and two secondaries/low side the latter of which can be wired series or parallel.
like infinity I'm just not seeing how one could get 240 and 480 simultaneously from the high side
