I do not believe for a moment that it actually provides a better connection.
I don't either, but it it less of a pain than wrapping stranded around terminals. That's why I prefer the backwired receptacles.
but why are you using a device that requires you to get a stranded wire to stay under a screw?
.... why are you using a device that requires you to get a stranded wire to stay under a screw?
Are any receptacles rated to take stranded wire without fork terminals?
Are any receptacles rated to take stranded wire with fork terminals?
I dont know too much but i think the Pass and Seymour CR series receptacles only accept solid.
RECEPTACLES FOR PLUGS AND
ATTACHMENT PLUGS (RTRT)
GENERAL
This category covers general use receptacles for use in wiring systems
recognized by ANSI/NFPA 70, ??National Electrical Code?? (NEC), and
outlets for use in appliances and fixtures. It also covers some attachment
plugs, male inlets, and cord connectors with nonstandard slot or blade
configurations which are part of a line of wiring devices including receptacles.
Other similar attachment plug devices are covered under Attachment
Plugs (AXGV).
Terminals of the wire-binding screw, setscrew, or screw-actuated back wired clamping types are suitable for use with both solid and stranded
building wires.
