Flex
- poestenkill ny
Im with you guys, i hook them all around the screws
Same here. If it squeezes out, I'll pinch the hook with needlenose pliers while tightening.
The forcing of stranded wire under a receptacle screw without tinning or pigtailing makes my skin crawl. This is of course my personal opinion. In my wildest dreams I would never think this was code compliant.
there is no way to get a reliable, full contact connection under a screw with stranded IMO unless its soldered
Are there any devices rated for back stabbing a #12 stranded wire?![]()
i'll agree with bob... i don't see a crimp on lug giving a better connection.
I will leave a tiny piece of insulation on the end of the standed wire when I wrap the wire around a screw terminal. The small piece of insulation will hold the strands together pretty good.
Chris
I would never try to crimp a fork on a piece of solid, unless I wrapped it back on itself.
yes. wago's..... not exactly a device, but....
I have a hard time believing or understanding how you would push a stranded wire into a wago without the strands going haywire? Does the wago open up and then you lay the wire into it and close it around the wire?
not the funky wagos that come with halo can lights... the good wago's
that are rated for stranded wire. they make an excellent connection on
stranded wire, if done correctly.
we beat that dead horse 2 weeks ago. you can view the carcass here:
http://forums.mikeholt.com/showthread.php?t=108516&highlight=wagos
randy
Are these the kind that you have to stick a small flathead in to open it up and then insert the stranded wire? If so then I can understand that.
ok. interesting.Nope, you just push the wire in the hole, thats it.
